1 - 20 of 35 Posts
Y
alrighty guys. i am wantin ti build a mini me. i have the z6 head already,well i have the whole engine,but the block has alot of miles on it. MY question is what would be the best block to use for this?
thanks
me
Y
i have a a6 block in my car but i dont want to use it b/c it has 240000 miles on it
I also install an a6 block in spring :hyper:
yeah i'm in the process of finding a d16a6.. and an 96-00 EX head and intake and tranny!
a6/z6 will give you around ~10:1 comp. ratio. If you already have the block rebuild it or find a low mileage one.
i did this but the oil pump faild :0wnage:
mill the head .030 and you should be close to around 10.7:1, which is a good place to start.
that'll give you around 10.10:1 comp. and rev pretty nice. It would proly work pretty well in your light crx (im assuming crx)
is that 20 bux for a healthy complete block? thats a steal!
D
I'm getting closer to 10.3 in my b7/z6 and love the revs. Small crank faster revs, has always worked for me, just ask my friends ls.
So the D15B7 will rev faster. Does a A6 block have a higher hp potential? I'm shooting for 12.6:1 comp in my mini-me
i have a d15b, it likes 8000rpm even without vtak
only cause displacment. 1.6>1.5
Y
Discussion Starter #19
alrighty guys, i am gona do a d15b7 block with a1 pistons and a z6 head , what u think the comp ratio will be
1 - 20 of 35 Posts
