1 - 9 of 9 Posts
Personally, I know I'm not the most knowledgeable, but I will help.
I would get 450 cc dsm injectors seeing as you are obd1, then put a resistor box in or just put resistors from radio shacked 10 watt 10 ohm. Of coarse you will need some kind of fuel management, so find someone to chip a p28 with crome or uberdata and you will be set with some form of tuning.
I run Blue tops on my obd1 turbo hatch, there low impedance which makes them "Peak and Hold" type which is why you need to wire up resistor box. Very easy too do and tune w/ these injectors :)
harryshonda said:
thanks for the info, just bid $50 for some low impd blue tops :p
Sweet! You will love them if you get them..
1 - 9 of 9 Posts
