1 - 7 of 7 Posts
I have a d16z6 under construction with srp pistons, eagle rods, and crower stage 2 cam and valvetrain. Which cluth is recomended and why. I currently have a 9 lb flywheel.
i am running an act xtreme pressure plate with a modified street disc.
i am shooting for 300whp........clutch is rated at 270 ft/lbs of torque. should hold up fine.
??? I'm using a stage 2 clutch with 11lb flywheel and I can get it to slip like a mofo if I power shift into 2nd or 3rd on 10psi T3 50trim stock internals.
If I roll on or punch it then it holds no prob and the tires break in 2nd.
are you using the question marks in the terms to question what i said????
just wondering......not a big deal. I was wondering if my clutch was gonna slip, but i figured it wouldnt, but if someones gonna question it, please explain.
1 - 7 of 7 Posts
