Need some help in setting the correct timing on my engine.
Setup
D16z6 Bottom End - Z6 Crank Pulley
D16Y8 Head
I have a d16z6 camshaft and camgear, Is it possible to use on the d16y8 head?
Will my timing be correct?
Or do I need to use a d16y8 camshaft and z6 camgear ?
Curious George
'99 LX Civic Sedan
IIRC, cam + cam gear need to match. So wouldn't matter if you used z6 cam + z6 gear or y8 cam + y8 gear. They just need to match.
Since you have a z6 block, stock with the z6 cam + z6 gear.
I'm sure someone will flame if I'm mistaken :)
I think you only need to match cam and cam gear of the same generation, that's it.
