1 - 7 of 7 Posts
CRX
Looking for some opinions on which block to use for sleeving.
I'm pretty much sold on using the z6 because of the better oiling properties and higher output of the oil pump compared to the Y series. But I like the fact the A6 has steel main caps. The build will be a 78mm high boost application. Any intelligent feedback will be appreciated. Thanks. :yes:
95 ex coupe
may i ask why you are doing 78mm?
i would think if your sleeving a block you wouldnt go that big of a bore.
same
its because of the slleves that he would be able to go with a 78mm bore. found out about benson sleeves. heard that they are super solid. they just keep the deck open. but the guy who ons the company does all the machining himself. they also mill to 0.0001in tolarances. and never heard of any sleeves dropping with this guy.
ej1
A6 block if you have one.
Ported z6 pump.
1 - 7 of 7 Posts
