1 - 7 of 7 Posts
same
I checked the sticky about compatibility for axles but I feel I didn't geta straight answer. should I use the dx axles in my 91 hatch with my z6/s20 combo or will the axles from my 94 ex coupe work fine. I really would like to clear this up so I can buy the right axles. planning on lowering the car about 1.9-2.0 in depending on the sprngs.thanks::sweatdrop:
use your dx axles the 92-95 are a tad bit to long
why ya putting a hydro trans in your car for?
not so sure on the axles.
Offset on the tranny is different. I know there is a thread on here about it and no I'm not gonna look it up.
same
the reason I'm using the hydro trans is because I have one. It works fine but I might use the si tranny from a crx. are they the same as far as quality goes other than one being hydro and the other being cable. where would I look for a si tranny for cheap then.
yay 69 posts!!!!! yeooowwwww!!!
same
hey transzex could you tell me where you found that info or what is the infoon those axles
1 - 7 of 7 Posts
