the only reason i asked was when i used the y8 head bolts to tighten the head after the swap, they were too short and ripped the top of the threads off inside the block. after that i used the other d15 set that i had, and they worked fine. unless i just got my bolts mixed up in the first place, in that case im just dumb.
YOu must have goten your bolts mixxed up becouse d15b and d16a6 and d16z6 head bolts are all the same, but y8 is differnt. I think y8 even has 1 thats longer than the rest.
one is shorter
