1 - 20 of 20 Posts
I'm putting a 1.5 motor in a EK chasis and I'd like to use the knock sensor. I thought I seen a how-to for something where a guy put it on the alternator bracket, but I can't find it. I've searched and I can't find any info on how to retrofit a knock sensor on an obd1 motor.
I thought I seen it on c-speedracing, but I didn't see it when I looked earlier. yeah that alternator bracket is way different on civic motors.
has anyone actually tried to drill and tap a hole for it??
peterbilt
I wonder if it work if you put the tip in water? in the EF fan thermoswitch hole
i dont think so
i thought there was a place for it on the head? shows how much i know
easier said then done. you'd have to find a pretty big drill.
I dunno I'd really have to look and see if its possible. then if I can find the tools.
yup...ive heard..although hard to find...a del sol si ecu from i believe its 96-97 model will work..its a p2p/obd2a and doesnt look for a knock sensor or fuel tank pressure sensor
1 - 20 of 20 Posts
