1 - 19 of 19 Posts
Ranger - work truck
buy a clutch kit take the tool then return the kit..... not something i would personally do, but to each their own.... you could say it didnt come with the allignment pin.....
^^ Hmmmm, I really don't wan't to do all that. I hate performance shops. Does the autozone one you can rent work??
I did a search on h-t. Someone said ( I have the motor removed to so....); just eye ball it as close as possible to center and tighten the bolts finger tight. Then install the tranny. Use the hole the starter goes in to tighten the bolts.
You could some what tighten them in a criss cross pattern without even marking them. Loctite on the pressure plate or flywheell?
1 - 19 of 19 Posts
