1 - 15 of 15 Posts
You would probebly have to have a company import it specially.
why would you want one?
Like getting D15 parts wasn't hard enough.
If you'd seen a puny D13 crank, you'd cry.
76mm stroke, PUNY crank.
I wanna be just like Jimmy!!
hondajosh said:
...you would def have to learn to...take nothin...fast...
there, i edited it so it sounds kinda right. ;-)
i really don't think that small of an engine has any sort of potential, honestly
Hmmm.... 76mm crank with custom rods to use a piston with a 27mm compression height and you could have some fun at 9K plus....
that's my thought, you'd have to lighten the hell out of the rotating assembly, but it would be like a sport bike engine
the crank is TOO light to begin with. Yes 1.8-2.0 RS is possible, but at a HUGE cost ($3000+)...............
At that point, simple D15/D16 on boost is WAY cheaper!!!!!!!!!!
Sleeves = $1000
Rods = $800
Pistons = $500
Headwork + cam/valvetrain is another $1000-$1500
$3300-$3800
i found this;
Civic 1.2 16V 1987-91 (D12)
4-cyl. 1193 ccm. 54 kW/ 73 hv
D12-moottori
cyl. 75mm
stroke 67,5mm
compression ratio 8,6:1
Translated from finnish text. there's many of those engines here.
Wow i could make a little 10,000rpm screamer. 16v should flow good on a 1.2l. Do you think the 88-91 d16 mpfi intake will fit? Where can i get one?
1 - 15 of 15 Posts
