1 - 17 of 17 Posts
Where tu buy cheap d16 Race Rods and +/-1g balanced high compression Piston ?
i want to rebuild an d16z6 with an crower stage 2 cam
does anybody know how the qualiti of this rods is? Honda Civic H Beam Rod Rods D16 ZC SOHC D Engine :eBay Motors (item 170414641557 end time Dec-31-09 17:05:37 PST)
because they are 100g lighter than the H bean eagle rods and also much cheaper
also i dont know if an ACL Rod Main Bearings Kit is enough ACL Rod Main Bearings Kit Civic CRX Si D16:eBay Motors (item 130348654016 end time Dec-07-09 16:37:57 PST)
ore if i need an ACL Race Main Rod Thrust Bearing ACL Race Main Rod Thrust Bearing Civic D16 D16A D16Z ZC:eBay Motors (item 270483527788 end time Dec-11-09 01:01:47 PST)
last but not least, i search for cheap balance high compression pistons, but i cant find cheaper one than ~500$
hope you can help me
nice greetings Techi
Lifetime Awesome Member
'89 CRX HF
Those rods will be fine, they are just like any other China made rod(same as Eagles except no fancy finishing). Only thing I don't like is that they do not come with rod bolts. Personally I would search around some more for ones with ARP 2000 bolts.
ACL bearings are fine and work well.
Are you looking for forged pistons? I like forged over Vitaras, but that is going to depend on your budget. SRP pistons are going to be your cheapest forged. If you want to run Vitaras, PM "fjt" on here about his sales, or just look at his threads in the Sponsors section
yeah that rod is cheap and less weight in that form, has no bolts!
thank you
did you know a cheap place to buy balnced high compression pistons?
the cheapest one on ebay are around 560 CP Pistons Honda Civic D16a6 CRX Si D16 75.5mm 11.0:1:eBay Motors (item 250473159372 end time Dec-24-09 12:37:30 PST)
in packag with H beam rods ( :-( ) thye wil cost around 780$ CP Pistons Eagle Rods Honda Civic D16 D16A6 D16Z6 D16Y8:eBay Motors (item 290359188949 end time Dec-11-09 14:01:22 PST)
also i found KSM pistons for 499$ http://www.honda-performance.com/info-lv2.asp?id=358
look into P29's. $150 for the set. there is also another brand out there i see people talking about, they say the design is better than the p29 cause of the dome the p29 has. but i hear they are hard to find? someone will chime in.
'89 CRX HF
Those i-beams are the exact ones I run. Built motor, t3/t4 @ 21psi...they hold up great and are lighter than h-beams.
p29s are a good choice, but you can get away with stock rods if you are doing a simple high comp build.
yes you can use the stock rods for n/a high comp build but i would recommend putting arp rod bolts in them and having them recon'd. i think the pistons sick1camcivic is refering to are pg6's they are alot more forgiving then a p29 and abit easier to tune but they have a tiny bit less dome then a p29 so lower comp
if you use an aftermarket set of rods u will have to buy aftermarket pistons as the pin that holds the stock piston to the rod is pressed and the aftermarket rods are full floating..
imho the stock rods shot peened with PG6 pistons is the way to go
1 - 17 of 17 Posts
