1 - 3 of 3 Posts
R
I swapped a 89crx dx motor out and am putting a zc in.. but the stock motor mount on the driver's side doesnt fit in very well.... or at all... anywhere i can find one, or a suitable part i can find to use i could find in a junkyard etc?
havent you seen my MOVIES?
CR-X
i dont know what its called, its the metal piece that bolts to the engine that you bolt the mount to... you have to use the metal piece from your stock engine... the zc one doesnt fit... blah its late hope this helps ya out
this thing! your stock mount is fine its just this piece need to be changed for your stock one, for some reason the zc one is differant
you have to take the crank pulley off and the plastic cover to get to it
R
Yeah, thats the piece i need. i replaced a stock d15b2, which had a sohc mount and despite my hours of grinding to get the stock mount to bolt on, it still doesnt line up with the body mount...
1 - 3 of 3 Posts
