1 - 11 of 11 Posts
hello everyone. I'm looking to purchase a bigger pulley for my jrsc to up the boost. Though i can not find out where to purchase one afer hours of searching on here and google. Can anyone be of assistance?? please and thank you.
a smaller pulley on the supercharger INCREASES. a bigger pulley DECREASES.
Its better to have a bigger crank pulley in my opinion.
a machinist shop can take care of you
Meat Popsicle
91 CRX Si
d16z6 and yes im using the oem crank pully. Would it be wiser to get the titanium crank pull as you did?
Then you probably need a 4-rib 3.2" blower pulley. The crank pulley I had made was aluminum and doesn't have a rubber dampener in it like the stock pulley does so I ended up using a Y8 crank pulley instead.
but i bought my jrsc without the belt.
Bando 4PK1220 is the belt you need
ok so im then im good with my crank pulley thats good to know. now i see most pulley range in boost. most say 9-12lbs of boost the 4rib 3.2 falls into that category? and i can purchase the belt anywhere(auto zone, advance auto, etc)??
Meat Popsicle
91 CRX Si
Belt cross reference list.
4PK is the 4-rib belt which is what you need.
Code:
Bando   Jobber Dayco    Gates   Goodyear
4PK1220 480K5  5040478  K040476 4040476
3PK1220 480K3  5030480  K030480 4030480
The 3.4" should give you 8-10 lbs of boost.
Code:
what pulley would give me 10-12lbs?
1 - 11 of 11 Posts
