1 - 7 of 7 Posts
I need two new CP 75.5 9:1 pistons. Where is the best place to get invididual pistons or does anyone on here want to split the cost of a complete set with rings with me?
I melted two pistons due to detonation:( Reason was it took me a long time to swap head studs when i head lift thus causing air to get into my system and super heated my chamber/head...
wow ..... Yes you do huh?
Most the time they are sold - in pairs of four but i don't see why couldn't buy just two. Call the place you got them from - maybe they can help you. The only issues i see if if they need to buy four to sell you two. And i can see their point from that side ...
sub-sponsor
Part #: SC7026
75.5 Comp Ratio 9.0:1
i'll do it for 120 and shipping...
edit for 2 it'll be 235 and shipping
Did det. blow out the valve reliefs on the pistons? Hard to see from the pic...but that's what I can tell. Does not every know yet that it's a good idea to file down the valve reliefs becuase of this very reason? My friend has a BNIB set of 20 over CPs at the machinists right now; guess what, he recommended him to file them down as did I.
Anyhow, hope after the piston replacement everything is good to go!
i called the place i got them from and i was just wondering if there are other places. Just trying to see where i can get the best price.
Part #: SC7026
thanks! do you stock rings too? if so what kind?
yup basicly cylinder 1 it blew the reliefs out completely you can see about 1/8 inch of the compression rings. cylinder 2 also blew out in teh same spot, but not as bad.
car still runs:) i havent pushed on it hard though.
1 - 7 of 7 Posts
