1 - 20 of 27 Posts
I can't read...
at what points on the motor do you use to get it out of there?
just looking for some input because i'm going to be doing this on saturday if everything goes as planned.
The H Badge is it!
91 crx
i put the rope (yes, rope.. we didnt have a chain lol) around the driverside mount, then i removed the distributor, threaded one of the bolts back in, then put the rope hook on the bolt.. worked fine, and motor works fine so far...
:werd: rope is the shit...i did mine similar.
Lifetime Awesome Member
'89 CRX HF
i wrap the chain around the driverside mount, and the other side around the passenger side transmission mount. i ALWAYS pull the 2 together
I can't read...
I always use the factory lifting points. One on the transmission and the one on the backside of the head above the alternator.
what is there to connect to on the factory lifting point on the head?
is it a bolt?
95 civic ex coupe
i just use the bolt hole on the back of the head by the intake manifold on the cam gear side... then i take the dizzy out and put a bolt there.. never had a problem
Reactions: myHonda1
yellow bar for me
viper blue 92 eg
i use the bolt holes for power steering and a dizzy whole. but i drop the engine out of the bottom. its just easier that way.
88 ED6
On the clutch cable bracket, there's a hole and i just stick the hook on there. then, i take one of the motor mount nut off, put the chain on there, and bolt the chain on there.
I can't read...
how do you raise your car that high? do you have a lift or something?
The H Badge is it!
91 crx
good advice is to raise the timing belt side a little higher than the tranny side.... makes life soooo much easier.... same for dropping it back in
yellow bar for me
viper blue 92 eg
ya i have a lift. but i also have a set of jacks that will lift it high enough to clear.
1 - 20 of 27 Posts
