1 - 10 of 10 Posts
Honda Civic?
I’m in the process of ordering a new wheel bearing and hub assembly along with a ball joint for the front driver’s side but I’m wondering if there is a seal that goes in between the rear of the hub and where the CV axle slides in? I can’t find one on RockAuto nor OEM parts.
car is a '99 EX 4-Door with ABS
Thanks,
Honda Civic?
really...? interesting.
alright thanks for the help, this is kind of what i was starting to think.
even though my Subaru has a sealed bearing in the front, it still has a dust seal, that's where i was thinking about the similarities
\/Your Mom Was Here\/
Vibe GT
I know the older cars used dust seals but the newer ones all seem to get away from that. There is a dust deflector on the end of the CV shaft (or at least there should be) that will deflector 99.9% of shit away.
EG8
If Beer is talking about the little metal ring on the backside of the hub, yes. That year has it.
But it's usually uncommon to find on cars that have been worked on... I barely see them because they were likely lost.
Honda Civic?
Thanks guys, yeah i was thinking there should be some sort of actual seal similiar to what is on the transmission side that the CV axle shaft with the C-clip goes through since that's an oil seal.
i guess if it's a sealed bearing, there's no need but i would imagine water intrusion would F the bearing up pretty quickly.
ej8
Yea the bearings are kinda seal and have very thick gease which should help keep water out.
Make sure you have a 20ton press when you do this job.
The is a extra rubber seal on the end of the axle, but the bearing is sealed so it doesn't really do much
1 - 10 of 10 Posts
