1 - 3 of 3 Posts
whats the relief valve piston and spring on the oil pump? Also, whats the oil control orofice with the head?
See above...
It's the mechanism that allows the oil the flow at different pressures. It's the same area where builders "shim" (add a washer) to increase the oil flow at different pressures.
Oil control orafice... ah, not sure.
1 - 3 of 3 Posts
