1 - 9 of 9 Posts
J
i've heard both d15b and d16z6.
any inisight, and reasons why?
O
d16z6 is a way stronger stock motor. better rods and crank. Head also way out flows the d15.
Z6 is a stronger base motor........
but oscar, the D15B and D16Z6 have the SAME SOHC VETC head so that is a moot point.
Touche.
the hard-parker
i'd say z6 just like everyone else, but i like the y8. mostly cause i'm biased :)
H
you could just spend the money and build up either block then it wont matter other wise z6 has stronger rods
I used to be Admin.....
I have heard Mark from Exospeed say that they like the a6 motors because they have the strongest bottom end.
B
All the d-series rods are pretty much the same (weak as shit). How much power a stock block will hold depends on fuel management and tuning. The 1g ZC (olive top) & 86-87 D16a1 have the biggest D-series rods by the way.
1 - 9 of 9 Posts
