1 - 20 of 25 Posts
CIVIC COUPE
Im nearing the end of my parts list and im wondering what or why would be better for my build. A 38MM WG or a 44MM WG?
ill be running the Goautoworks AC ramhorn manifold but i need to decide on WG flange too. does it matter what size or is there a reason for it?
thanks for the help
larger WG can re-route more gas to control boost better. this is only necessary if you are trying to run low boost
a 38mm will work for 99% of everyone on a properly designed manifold
CIVIC COUPE
ok so since im shooting for 400whp and my boost will be around 20-30psi a 38 will work fine then correct?
man i thought this was a boobie thread
lol funny.
sorry for the disappointment
honda/firebird form.
yes 38mm is the most widely used wastegate around.. like dan said, the bigger the wastegate= the better the flow which means it will control boost better, which is intended for lower boosted setups.
CIVIC COUPE
Are you going to do boost by gear at all ? If the lowest boost you will see is 20psi, 38mm will be just fine.
that would be cool but not in the plans right now. just trying to get what little i have left to get my vitara build in and running.
could always do a dual 38 f you have issues down the road
^Haha, that was exactly what I was thinking of doing. Dual 38mm wastegate or just a single 44mm wastegate. I should of never sold my other tial 38mm wastegate.
hotrexs' fail back in the day
that wasnt back in the day, thats the HOMO that he just recently blew up isnt it?
lol
doesnt matter, bact to OP
1 - 20 of 25 Posts
