1 - 13 of 13 Posts
over bore to 75.5mm (stock 75mm)
z6 crankshaft
wiseco forged pistons 75.5mm
eagle H-beam connecting rods
supertech block guard
high flow oil pump
honda main/rod bearings
ARP headstuds
HEAD:
Blox stage 2 turbo camshaft
AEM adjustable cam gear
Brian Crower stainless steel exhaust/intake valves
Brain Crower titanium valve springs & retainers
Supertech valve stem seals
Cometic head gasket
Skunk2 pro-series intake manifold
Skunk2 70mm throttle body
TURBO:
SPA top mount turbo manifold
P28 ecu (obdI)
conversion harness (obd1 to obd2)
HKS super sequential BOV
Grimmspeed manual boost controller
steel braided oil feed & drain lines
omni 3bar map sensor
3" downpipe/exhaust
Precision Turbo 57mm 3431 5-bolt .63 A/R
Precision 39mm wastegate
custom wastegate dump pipe
Walboro 255 e85 fuel pump
Greddy 3” front intercooler
Intercooler piping black (600+hp)
1200cc fiveo fuel injectors w/ resistor box
other:
AEM UEGO wideband controller
Blox oil pressure gauge + Blow oil temp. + Autometer boost gauge
BLOX Oil filter sandwich adapter
Stage 4 competition clutch
Blox 10" slim radiator fan
XXR 531 wheels, powder coated white
Form and Function type one fully adjustable coilovers
yeah my build is done I want to post up some pictures! I moved to south Florida and am in need of a tuner to run Neptune, anyone know of any good tuners down here?
98 Civic HX D16Y5
Right on! Get that thing tuned and dyno'd let's see vid and pics and definitely a dyno sheet!
Sounds like a fun ride.
98 Civic HX D16Y5
Use another photo/video hosting site(photobucket, imgshack, etc) then just post links. BTW the vid post just says "vid".
Car looks good. Mostly stock on the outside? I like the blue bay.
That turbo looks good up there too!
EG8
Depends on where in South Florida... If you are Sarasota I heard good things about ART from Boost Lab, they might not have direct Neptune experience though.
If you are closer to Tampa area, there are a lot more options.
Love the Civic
I dig the coastal view in the bay as well.
1 - 13 of 13 Posts
