1 - 12 of 12 Posts
im currently running a stock d16y8 with a small t3 on it and i dont really like it but it does its job i guess. i have a block in my garage that i am waiting to get sleeved and then pistons rods etc. the turbo is def. capable for what hp i want but i was wondering if it would spool ok if i bought it and ran it on my stock d16y8?? or should i just wait till my sleeved block is on before i get it??
let me know thanks for the opinions!!!
also let me know about dif. turbos that you think might work or be better for my application!!
http://www.rx7store.net/product_p/garrett gt2876r.htm
sub-sponsor
you dont really need sleeves unless yours are messed up, but 42 48 t3s hit full boost at like 3k lol
First of all what is your budget?
x2 or if u plan on exceeding 400 hp
and my .42/.48 wont reach full boost till 4k because of the 12 valves in low cam mode... :(
my t3 doesnt pull full boost till about 4500 or 5k rpms i just found a leak on the welding on the manifold :noway:. i was just going to run sleeves that way im safe for 400+ and between 20-30 psi. u think those numbers are ok on stock sleeves with pistons and rods?? and what turbo do you recomend for those numbers
and for my budget i dont know what exactly it is but i just try to figure out what things will be best for my car and i save up to get them i want to get pretty good set of pistons and rods that way i know they will last and i want a good lasting turbo. just let me know what you guys think i should do and i will find a way to get it lol
1 - 12 of 12 Posts
