1 - 20 of 59 Posts
Feel free to move this thread but I felt like it would get the most views and reply's here.
We're launching a whole how to video section and we'd like to hear the input of fellow d-series.org members.What would you like to see us cover ? What have you always been curious about and would like an answer to ? A product explained, an install or job how to ? Lets hear some ideas, we wanna make the first few videos geared towards you guys.
96,97,00 civic
Can a rear mount turbo set-up be made to be efficient? Or can a twin turbo v car converted to single carry over the same driving dynamics or will lag(transient response what ever people call it these day) be a necessary evil? I know this has nothing to do with the D but I am curious
I would ask you to define what you would consider efficient in this type of application .
As for the twin to single discussion, we could open up a whole bag of worms that could turn into a presidential town hall debate.
ED6&7. EE4&5, MB1
How about the following:
Proper / recommended way of running oil and coolant lines on D16 turbo setups?
- input / output
- line sizes
- oil restrictor usage
Proper / recommended way of using catch can on boosted applications?
- with / without PCV valve
- atmosphere venting / recirculated
Personally I have seen way too many different approaches when searching for valid information.
Why EWG placement is so important.
Although it could be costly to produce identical fanimoulds with differemt placements.
'92 CX Twincharged D
Build D16/15 engine blocks, basic how clean is clean, bearing clearances, ring gaps.
Sleeve or not to sleeve, depends on HPP goals
Choosing the right camshaft, valvetrain
proper head stud installs, maybe include time-serts for repairs, use of time-serts for all head studs for x amount hp goals.
Notching blocks for which rods,
Vid on the different build stages of engines you offer
Cylinder head prep, porting, valve prep, valve seats, springs differences from different manufactures.
Car prep for drag vs. road race vs. street
Clutch choices, whats best for the above mentioned.
Just brain storming some ideas here.
I watch a lot of the Real Street Videos on Youtube, learned a bit, but no info for d16/15 force induction. :-(
First off, I'm very happy with all the responses and was super excited to jump into this thread this morning hoping people had some good ideas.
Engine building gets a little complicated for two reasons, we don't want people to listen to our opinions with out doing proper research on specing clearances. A lot of poeple will only read into half of something then put blame on us if something were to fail ect ( well they said this, they said that but in reality you never fully watched all of the video ect...... ) The other reason being is we feel like other companies can use some of this valuable information to gain business, basically the copy cat approach . We don't mind helping others out, we just don't like companies that leech off of others that put in the time and research. Hopefully that makes some sense.
The other stuff we can definitely dip into a little bit more, but we would need to build around some of those topics so the videos weren't to short.
I would enjoy a video on tuning in real time. Like dyno tuning
We could do something like that but we'd wanna keep it really simple though and we would also have to put a disclaimer so people just don't automatically think they can tune the world. We'd also have to dumb it down a little bit just because we wouldn't want companies to act like leeches ( read down more on my explanation on this )
We could make a video on this, and also explain why some manifolds suffer more then others, the mini ram being one of those that a lot of people don't think would have boost creep issues but they do, due to how small the collector is.
- input / output
- line sizes
Coolant lines, for water cooled turbos ?
We could definetly do a video of different methods in connecting a feed and return line .
Catch can information , we could do something like that. We could explain when a bigger can is needed over a smaller can , we could get into the pcv system ect...
Maybe you could discuss cam timing for head swaps on D series engines. You could also demonstrate how to degree a camshaft. Maybe that video could also discuss how to make more power through adjusting cam timing or how to effectively shift the power band throughout the RPM range through cam timing adjustments.
someone beat me to it with the oil lines for the turbo.
how about plumbing the vacuum lines for the blow off and wastegate, or boost controller.
or oil cooler lines/relocation of filter
96,97,00 civic
Sorry for my vagueness I was referring to efficiency of the turbo system itself not the mpg's of the car. Is it possible to retain good turbo response with remote mounted turbo's
D series engine building, complete tuning video from beginning to end with good explanation of the fuel tables, advance timing, etc..
What about on manis in general then?
Cast vs log vs mini ramhorn vs equal length and the assosiated wastegate.
A back to back dyno session with each mani would be ace. Showing the graph of each too.
This is simple enough, we could do that.
We would prefer to have a mini me setup here to discuss that, we could go into detail on how power is made by adjusting the cams but on a single cam its not something that is really done anymore because of the time it takes, and the power you gain. Time is money to most people, so unless we're doing a really wild N/A build , or a higher horsepower build, cam gears usually aren't messed with.
Got ya, I myself believe so. Well lets just say, as good as response as you're going to get in a remote system.
This really sounds like a guide to help people not more so understand tuning but to do it themselves. It almost falls in the line of having "another" shop watch it, take notes and learn to tune off of us. We have no issue though explaining the basics of a dyno tune, as I think this information would be great for a lot of people that don't have an idea what happens during a tune. We get phone calls every day where we have to explain what exactly happens during a dyno tune, so I'd be willing to make a video going into details about that.
We would really need a guinea pig for that.
Two men shy of a group
99 civic sedan ex
What about some sort of vip video access so that only daily users of dso could watch the dyno tuning video,that way it can't be easily viewed by any tuner? I know alot of people could really benefit from this. I know I don't have money and really don't want to pay for another dyno tune after the last tuner I had do my car but I'm almost forced to because of the issues I can't figure out, only problem with this would be having to show all tuning programs ie: crome,neptune,hondata,ectune.
Maybe you could go more into detail only on the things like ect and iat tables and ignition, crome has a pretty decent guide but some of the things are vague on whether only one sensor is used or multiple sensors are used.
I think you just proved his point. I have spent thousands of hours and 10 years learning the tuning business. I don't mind sharing the basics and even timing numbers as its not a art form, it a science. However, to ask someone to go in detail a step by step instruction guide is a little too much, that's what we get paid to do. There are too many variables and different setups to cover. A basic guide of what to expect and in general what we do is one thing, but the ins and outs of programming is a different story.
Discussion Starter #17 (Edited)
We under stand your frustration and that is one of the main reasons why we started to sell our blocks world wide, not everyone in the world has a shop like us around them.
I see where you're going with the vip and payed subscription deal but if another shop thought it was going to be something worth viewing, whats $20 to them or what ever we decide to have it sell for.
We're all about going into the basics though, don't get me wrong on that. I will tell you though, the only program we'd be willing to do this on that would be the least expensive would be neptune. Chrome just has so many issues ( buggy ) and its one of the reasons we'll no longer tune on it.
There's just a fine line of serving people with knowledge and them using it to help themselves, or serving them with knowledge and have them think they're a professional tuner and street tuning everyone in their neighbor hood and cutting the throats of professional shops.
Discussion Starter #18
Very well put, thank you.
When someone breaks down the price of a dyno tune you have to remember you're not only paying for the knowledge of that tuner ( and time ) , but take the other factors into considerations that we have to pay yearly, such as maintenance on the dyno, schooling that might be needed, equipment such as straps, fans, 02 sensors, ( clean up when cars pop a radiator line or leak oil ) and the overall price the dyno itself cost.
The one question that we get asked a lot when people call in for a tune, well how many pulls do you make. It doesn't work like that, we do as many pulls is needed to get the car exactly where its suppose to be. We don't rush, we don't kick stuff out if we're closing in 30 minutes, we stay late and still always charge the same amount.
I get what you are saying, but I don't understand why most tuners are so secretive or dont like sharing knowledge about tuning. Why can't I know what you know, just because I see a complete video on how to tune does not make me a master tuner. I do not own a dyno myself. I would like to know just to be able to troubleshoot any tuning problems that may occur later.
Id love to see before and after dyno comparisons of anything and everything.
With how big the Honda community is, this kind of info is pretty lacking. There are lots of dynos for all sorts of parts and setups, but without anything to compare them to they are useless.
1 - 20 of 59 Posts
