1 - 19 of 19 Posts
I currently have 2 honda engines. the first is a stock Zc vtec and the second is a sohc zc non vtec that is also stock. which block is stronger or worth building up. i want it to handle 250hp at the wheels. ill be using a td05 dsm turbo and building one or the other blocks with oem bearing, tt rods, and vitaras. should i put the vtec head on the non vtec block and build it, or just build up the zc vtec??
1.8 nawz powa
Well there at minor things. Some people think you need to boost non-vtec motors cause when the vtec changes you lose boost. Most of the non-vtec motors have lower comp too whihc make then good for boosting. Personally I think the zc vtec would be a little beast turboed. A buddy of mine had one that was n/a and he put down more torque than hp haha.
Lifetime Awesome Member
'89 CRX HF
the blocks are going to have the same limitations. the rods are the same in each, the compression ratio are pretty close to the same, so in stock form they are of equal strength.
z6 with Vitaras will yield a better compression ratio than the non vtec zc. id run the ZC now and build the z6
yellow bar for me
viper blue 92 eg
i say run the ZC vtec. either way, both of them have the same limitations. and i dont think 250whp is capable with a td05. if it is, you'll be pushing it pretty hard. i would go with a .48 .60 for those power levels
Discussion Starter · #10 ·
is there any other turbo's i could use that would work well for 250hp that came on a stock car?
I can't read...
this might help. it's most of the turbo's with their wastegate settings.
also off homemadeturbo.com
Garrett T3 42/48 - 8psi
Most all chrysler 2.2l turbos w/ the goofy t3 - 5.5psi-6.5
.60/.63 Tbird/meurker/svo - 10psi
RHB5 from the Subaru and Probe - 8psi
84-88 nissan 300z t3 .60ar/.63ex. - 5psi
87-88 rx7 twin scroll turbo - 6.2psi
Mitsu TD04L(WRX) - 7 psi
t25/14b (Mitsu Eclipse) - 8psi
starion 14g Before 1987 - 7psi
starion 1987+ - 11 psi
garret t28 stage 1 - 8.5 psi
garret t28 stage 2 - 10.5psi
garret t28 stage 3 - 15 psi
K26 external - 14psi
GReddy 15g (mitsu td04h-15g) - 5.5psi
CT26 (MK3 Supra) - 5psi
TB25 (Garrett, 89 Pontiac Sunbird GT) - 7 psi
IHI VJ20 (JDM Mazda 1.8 GTX) - 8.8 psi
K03 - 4 psi
1.8 nawz powa
K03 - 4 psi
You like homemadeturbo.com dont ya man.
Discussion Starter · #17 ·
i was told by a guy who rebuilds dsm turbos that a 14b can put out 20psi with a boost controler so how come that turbo couldn't make 250hp on my build?
Discussion Starter · #19 ·
that compression ratio should work cause ill be using 91 octane only on this engine. thanks ryan!
1 - 19 of 19 Posts
