Okay, so in an effort to figure out what my cooling issue has been, I pulled the head yesterday and removed the SCE copper HG and decided to install a OEM D16Z6 HG.
My instructions for the ARP said 60 ft/lbs with their moly lube, or 80 with 30 weight motor oil. I had used up the moly lube on the initial install so I decided to use motor oil. I didn't feel real comfortable with the idea of 80 ftlbs on a alum block, so I figured I'd just go up to 70...
Okay, so install goes well, I go multiple steps up to 70. I was going over once more and literally I was at the last stud. I noticed that it started to give. I'm assuming that the threads in the block started to give. The motor was never started with the OEM HG installed...
So here's my options...
1 - Leave it as is, hoping that the final stud (corner stud) is ok and run it like that.
2 - Pull the head, fix it with a helicoil and reinstall using the OEM HG.
3 - Pull the head, fix it with a helicoil and reinstall getting a new OEM.
I'm leaning towards 2 or 3, but I was wondering if I need to toss the new gasket I put on.
Thanks
Drew
Thanks
Drew
