1 - 9 of 9 Posts
I know a noob question. By the picture...does this side go to flywheel or pressure plate??
Thanks in advance!
hard to tell from that pic, id like to see the other side...
but what ever side extends out more than the other faces the PP and the flatter/flusher side goes against the flywheel.
Thanks Danz! will have a look and take another pic tonigt if i can't figure it out!
Much appreciated!
Does it even matter with a solid hub?
to answer your question and now after putting the clutch in I see. YES it does. the clutch plates will only sit against the flywheel if you install it longer side towards trans and flat side on Flywheel. If you install it backwards the disk will not touch the flywheel!
thanks for everyone's help!
1 - 9 of 9 Posts
