WHAT U GUYS THINK ABOUT MY BUILD
588 Views 9 Replies 5 Participants Last post by  Jimster480
Hi I got a d16y8 and I’m pretty excited to start buy my internals I need some help
For the block i about to get CP Carrillo pistons and Eagle rods or my second option wiseco and eagle rods
Y8 crank and drag oil pump
For the head i was thinking about new valve guides super tech
Super tech or Ferrera valves
Super tech springs titanium reteirnes
New seals
Super tech or Brian crower springs
Bisimoto level x Cam
Coil and plug
s300v3
Turbo kit still thinking on it
1 - 10 of 10 Posts
What are your goals? Power level? Street car? Race car?
I was thinking street high boost for race but I got a dilemma with A/c and steering pump my goals it’s about 550 whp or little more
pick a different engine
I like the d16y8 just because I want to beat up someone with a single cam that’s the only reason really
then bring that number down a few hundred.
or turn it into an f2/23
You can have a lot of fun and do it pretty cheaply to 400 hp (vitara/headstuds with some no notch rods). Once you go above that you should really think of going K series. The only reason people on here build north of 500 is because they are in love with the single cam. To hold over 500 reliably you will need to at a minimum css the block, and prob invest in larger diameter headstuds (they like to blow headgaskets) and maybe a good cam.
Reactions: 2
I repeat:
Ecoregion Vertebrate Cartoon Natural environment Mammal
Cartoon Building Art Font House
Cartoon Art Motor vehicle Vehicle door Painting
Cartoon Green Art Wood Fictional character
You can beat up most things at 350whp while getting your car weight down to about 2100lbs, and you can take on most newer cars under 800hp.
Its all about power to weight.
Agreed. I went through this making 400+ and I went through ALOT of head Gaskets once I was up over 20PSI of boost. Didn't matter what head studs I got; I kept stretching them. I was like personal friends with the fastener companies because the head gaskets just kept going and the head studs stretching. I even made some custom sleeves to increase the pressure on the head gasket which helped a bit...
1 - 10 of 10 Posts
