1 - 4 of 4 Posts
Bought this turbo and idk what is that ( 350$ with mini ram)??
Thanks for replay!
94 Integra
Are you listing the biggest and smallest diameters of both wheels, or a possible range for the smallest for both wheels? You need to be w/in 1mm otherwise you just narrow it down to 2-4 types. Help me help you - explain your measurements.
If the intake wheel was 60mm/small and 75mm/large then it'd most likely be a 60-1. However if the turbine is 45mm/small and 54mm/large then it's likely a T25 turbine. But they don't make a T25 housing in 0.82, so I'd guess you measured wrong. A stage 1 wheel measusures 48mm/small and 58mm/large.
In any case, here's a chart that lists the vast majority of popular Garrett wheels with t3 turbines at the bottom:
Turbo Compressor Chart
1 - 4 of 4 Posts
