1 - 9 of 9 Posts
93 eg bubble
Im new to this site so help me out ..Right now I have vatara pistions. My 1st and 2nd cylinder aren't working, dont no why, I bought ngk wires an iridium spark plugs but nothing happened ! I asked one of my friends an he said that the cylinders might be dead. . Anyways I was wondering if that block would still be good if I bought new pistons an rebuilt that one !. WHAT Pistions do u suggest to run atleast 20lbs of boost witout having a problem .
94 Integra
Do you get new axles, hubs, rims, and tires when your valve stem leaks? If so, do a rebuild. If not, find the actual problem first. It would suck to have the same issue after rebuilding the motor.
To answer your question, Vitaras may take 20psi if you get it rebuilt, broken-in, and tuned right. Mess up one of those and the hand of god wouldn't even hold 20psi.
Well.......
Do a compression test, and a leak down test. If you dont know how to do it, then I would suggest that you find someone mechanically inclined to help you.
88 hatch
I would also ditch those iridium plugs and just get a standard ngk plug for when you get the problem fixed.
1 - 9 of 9 Posts
