I just bought a used Chikara header and I'm going to have to make my own gasket for in between the two pieces. What should I use? I was thinking to use some of that copper gasket paste, but I don't know if that will seal well.
Andrew
· D-Series Destruction Master
Andrew
just go get an OEM gasket from your local dealership.
I've been using this stuff for about 5 years now, and I've never had an exhaust leak at the head, or at any header flanges:
http://www.permatex.com/auto/autouh.asp?automotive=yes&f_call=get_item&item_no=81878
You have to clean the surfaces well. Use acetone or some other strong solvent. The mating surfaces have to be relatively flat and parralel. Make a 1/8" diameter bead all around the openings. Let the bead set for about 30 minutes. Bolt it together and let it dry for a couple hours. You now have a semi flexible seal that will not leak. Don't need the gasket at all. I have had brand new gaskets that did not seal because the surfaces were not that great. This stuff takes up some minor imperfections that would not otherwise seal up.
I have to credit The Old One for this tidbit.
