1 - 20 of 21 Posts
Hi guys i have a d16zc no v tec turbo vitara, eagle
Garrett t3t4 57 trim turbo with ramhorn looking to get around 350 whp if posible more ... Right now my head is stock i looking to build my head but i dont no what to put in first ? And i dont what to port it
So if you guys can help me out that whould be cool , thanks
new springs, new oem retainers, and rebuild with new seals.
no need to port for a low 350whp
Knowledge should fill your head. For your car? I would upgrade the springs and retainers if I am gunna rev the shit out of it.
You can go with blox really, its gunna be how much money you wanna spend and whos parts you trust. But like said above stock heads with oem parts can take a beating if you tune well and dont take it to the limit on the revs.
all built D series motors should be built to allow 8-9k rpm
supertech is a budget but quality spring set to use.
DO NOT USE springs from a certain california based company. they are too 'b'izy to care about you.
Iskendarian makes good valve springs.
Ferraera makes excellent valves, but OEM valves are OK
Titanium retainers from any reputable source should be OK. If Iskendarian offer them with the springs that could be a good idea.
aren't Ti retainers supposed to last less longer than steel ones? if engine longevity is important, would they still be a good idea?
Yes, titanium stuff has a shorter life.
but some people care more about that 0.001hp that they offer
Discussion Starter #16
I think il go with bisimoto spring with oem retainers
With ferrea 6000 valves !!
And as for the cam bisimoto Has good cam what level should be good for 350-400whp + whp??
Level 2 or level 2.3 ?
Its for daly drive to so i want a good idle to
keep in mind
a good turbo cam is nearly identical to an allmotor cam.
you have many to choose from
web(bisimoto sources through them, so bypass bisimoto)
colt
delta
zex
even blox does cam copies. not the best for supporting businesses, but we are not all privileged with heavy wallets
EDIT people HAVE used the stock camshaft up and over 600whp
dont think a cam is a requirement. Honda designed our motors to be VERY efficient for cheap. your average mild cam will do plenty of performance enhancement! no need to go wild!
Discussion Starter #19
keep in mind
colt
delta
zex
very good info and good to no thanks men :)
look for a stage 3 V-tec head to put on instead it will pull hard
Don't listen to this fella. No offense to you, sir, but your comment isn't worth a velvet painting of a whale and a dolphin getting it on.
To make my post worth while, you don't have to do anything to the head to support your goal. Although, I would change all the seals to prevent future downtime
1 - 20 of 21 Posts
