power surges
Let me start off by saying...i know i should have just changed the t belt
so i drop in a p08 ecu and a jdm d15b vtec. vtec had yet to be wired. i changed the plugs and plug wires. the belts seemed new so i didnt change them...i know this was stupid but the budget was tight and i was impatient. cranks up perfect on the first try. i drive a couple of miles the first day and leave it running while it sits for 5 min...in this 5 min the lower rad hose pops off and car shudders...i cut the motor off...PROPERLY attach hose..fill with fluid...turn key to where the gauges are on...temp seems fine ....so i turn the key and she fires right up (sorry for bad grammar...its a long story im trying to make short). i think the fan sensor had gone bad (least of my worries). ANYWAY....i drive around and she ran GREAT..till about mile 60 at this point im lightly on the throttle and its acting as though im going from 0% throttle to wide open INSTANTLY back and fourth...tach and spedo are acting funny...the check engine light is blinking erratically also (NOTE: the light was full on before, i think because i had yet to hook up vtec). i manage to limp her back 8 miles to my house just as it died. during this time i heard 0 metal on metal noises. sometimes while it was lurching it would miss fire. the t belt appears to be 2-3 teeth off time. i spoke to a honda mechanic and he said if im lucky all i need is a new timing belt...if im not...i effed up some valves. if anyone has any advise PLEASE help. im in the raleigh nc area if that helps. i figured i could do a compression test and that could tell me if ive messed up some valves but i cant seem to find a guide as to how to do that. as mentioned at the beginning...I KNOW i messed up by not changing the belts. :3dtard:
