kinda, the build remained relatively mild until last winter, i was going to piece together a mild budget turbo setup over the course of a couple years. next thing you know a couple months later im hacking the car up and just dove in head first. still a super budget built. i think i kept it under the $3k mark without sacrificing anything.
-inlinepro cast manifold
-hx35 (8-blade)
-tial 38mm w/g
-i welded up the 3" v-band downpipe and exhaust
-v-mount radiator and intercooler
-ebay intercooler piping
-ebay fake tial bov
-bosch 1300cc injectors
-aem fpr
-ebay surge tank
-aem 400lph surge tank pump (stock pump as a lifter pump)
-running e85
-oil filter relocation and cooler
-act hd pp and oem ap2 clutch disc (5-550whp capable setup)
-aem series 1 ecu
-aem wideband
-a bunch of sensor wired into the ecu
-fully ducted cooling system from the front bumper to out the hood
-im sure there is more im forgeting
-street tuned by mikey at touge factory but only about 80% done with tuning stuff, need to rent some dyno time for mikey to play with advanced boost controls and get boost by tps cooking and iron out a few other things.
but the thing can put some laps down with zero cooling issues. currently on 285 square re71s so i only get a outlap and about two flyer laps before the tires get greased up. i did do about 6-7 laps around autobahn cc at about 7/10th on the cars shakedown and car stayed 190-200* with 105* ambient temps.
not sure who that was but not me
unfortunately not yet so i dont have a track midwest opinion
. shooting for 38s next season, still working out setup bugs. mostly i have some alignment issues that were causing issues, i was hyper focused getting the turbo/engine setup dialed i neglected some suspension components, tried to drive through it but found the limits. seized camber adjuster in the rear so im stuck at like 1.9*, caster is way fucked, front sway bar endlinks started stripping out and are loose, and overall needs a bushing refresh.
also why wait till after pri
