1 - 4 of 4 Posts
I currently own a 2000 honda civic lx, its a sedan 4 door. What brand of coilovers should I go with? I will be using this car as a daily driver soon.
has suspension question, posts in engine building section......
stock. whatever 1aauto sells, or rock auto, or napa, or wherever you shop. while youre down there, look into replacing bushings
do you actually need coilovers for a daily? how often do you intend to adjust car height?
people forget that every ride height change needs an alignment.
Buy a set of those cheap cookie cutter china coilovers on ebay for 200 bucks. Use them to find a ride height you want. Then see about matching that height with a static or progressive rate spring, and toss them over a set of Koni Yellows or Oranges.
Prelude, Integra DB9
Good point. The BC coilies I use are very good value. Thing is, once I found a setting that works well on the shitty B roads we have over here, I found they were also good on the much better tarmac in Germany ...
... so I haven't adjusted them in years.
1 - 4 of 4 Posts
