I am woundering what spec you have on your d16z6.
I am going to build one for my mini so it would be nice to get some spec/ tips and what HP you have.
I need a real "Tiny" turbo due to The very limited space in The mini does any one have any tips on that?
Thanks in advance!
Most guys have motors making in between 115-120 and up to 150-160 all motor, and turbo motors ranging from 150-500+. Over 200whp can be made with a small turbo. Also if a buddy of mine can put a B18C into a mini, there is plenty of room for a z6.
Well.......
This.
Also the knowledge you seek is here
Showcase - D-series.org
And here
http://www.d-series.org/forums/forced-induction/131762-d-series-turbo-build-threads.html
And here
http://www.d-series.org/forums/naturally-aspirated/14618-current-d-series-project-engines.html
And here
http://www.d-series.org/forums/naturally-aspirated/141626-naturally-aspirated-faq.html
And here
http://www.d-series.org/forums/engine-building/
Now, browse through them, read the stickies at the top is the section and report back with any intelligent questions
there are a few people around my area running k series minis. if that can be done then you should have room for a decent sized turbo. worst case you can fab up a manifold to fit the turbo where needed.
compression bump plus skunk2 or edelbrock IM plus a 59300 or similar NA cam should get you to ~150-160whp easily and cheaply
