Hey hows it goin im building my motor for my crx its a d16z6 im looking to turbo it just curious what size turbo i should go with if im lookin for a fast spool and a max of 15psi. I have forged internals the block has been bored .20 over im just piecing it together and thought you guys would be able to help me out thanx i appreciate your time.
BseriesKllR said:
no i would def go bigger then a dsm t25....i think a T3 .48/.60 would be perfect for your goals.
with so little info i would also suggest either the 48/60, or the 63/60.
matt
if you want something that spools fast the t25 will spool very fast its a small turbo about the size of a cd but the t3 it bigger and you said you have internals so you can crank up the boost then the t3 would be good to consider it will spool nice and not die off it should hold a real nice boost.
If you got forged internals a T25 as not worth your time, nor it is near what you could make. Strong bottom end, get a T3 at least, I hear the Garrett T3Super 60 trim will put out great results, little more spool time, but well worth it for your bottom end.
