1 - 7 of 7 Posts
ok i need a list of stuff that i should replace in my build
oil pump
water pump
timeing belt
seals
bearings
is there anything else?
Oil pan gasket
oil pickup gasket
timing belt tensioner
head gasket
IM gasket
exhaust gasket
valve seals
valve cover gasket
cam end seals (if needed)
distributer o-ring (if needed)
piston rings (for the piston you plan on using)
That's all I can think of off the top of my head.
-Des!
i save your ass when you wreck
new plugs, wires, oil pump, water pump, all gaskets, timing belt, tensioner, etc
1 - 7 of 7 Posts
