1 - 2 of 2 Posts
X
i have a d16a1, with a 89 teggy trans and need a new clutch. i know the teggy clutch will work, but was wondering if theres any others that are a bit more available and cheaper on the market.
the SOHC version of the ZC is the D16A6, and its clutch should interchange with it, plus it should be pretty cheap, i think the driven disc diameter is 212mm, so that should help you find one. (which it should, most d blocks use a 212mm disc)
1 - 2 of 2 Posts
