1 - 20 of 49 Posts
ej2
This will be my first oil change since doing my swap.
3000 miles in..and i'm still use to getting castrol gtx high mileage with the fram oil filter:yes:
any suggestions on what would be good to use?
Ive heard that too, but Im not sure how much truth there is too it.
My car has had nothing but mobile 1 synthetic for the past 100k miles
68 Camaro
pennzoil is a no no after long periods of use
i like valvoline
ej2
Thanks Cm!!
I thats wat i was leaning towards.
valvoline, gtx, or rotella or something= ]
1988 Honda CRX
Mobil 1, Castrol Edge and Ams Oils are all good oils
Im Bringing TSEXY Back!
^^Look up
Mobile 1 synthetic FTW
Mobil 1 FTL!
Apparently you guys have never seen that oil test results on this site?
I can't remember the link but when they tested 30 diffrent oils and showed the metal to metal contact wear Mobil 1 was'nt even in the top ten!
Royal Purple finished number 1 ans is definelty FTW!
Mobil 1 FTL!
Im really surprised to hear that.
I know several engine builders and sports car racers that use nothing bud mobile 1 synthetic, which is why I have always used it.
On the other hand, Ive heard lots of royal purple horror stories.
So yah, idk, haha
93' lx
So yah, idk, haha
Really? please share thease royal purple horror stories.I got an increase of 2mpg city and about 5mph hwy when switching from valvoline maxlife to RP.
to OP if you dont wanna spend $8+ a quart i'd just use whichever blend of valvoline you choose, cant remember how much their synthetic goes for but i know the maxlife which is a blend and it does good for the price is @ 16-18 buck for the 5quart jug @ here a wallmart.
but one thing dont cheap out on an oil filter, go and get yourself a purolator gold filter.
Ive heard from a few people that RP is good at making power, but doesnt offer the protection of most oils. Which is completely contrary to what T-Mack said, so who knows.
Admittedly, I dont know anybody personally that has had an issue with RP, but I seem to recall hearing bad stories about it on a few occasions.
Im gonna do some searching for some oil comparisons on the interweb.
Heres one:
Oils Against Oils - Major Oil Brands go head-to-head on the dyno.
WEAR METAL TEST
Indicates size and number of wear particle for each oil. The higher the rating the greater number and size of wear particles.
#1 Amsoil Series 5-10 micron
#2 Hi-Tec HTO 15-20 micron
#3 BP Visco 5000 15-20 micron
#4 Shell Helix Ultra 15-25 micron
#5 Shell Helix Plus 10-20 micron
#6 Mobil 1 5W-50 20-25 micron
#7 Mobil 1 0W-40 15-20 micron
#8 Castrol R 20-30 micron
#9 Torco 15-20 micron
#10 Royal Purple 15-20 micron
#11 Castrol SLX 20-25 micron
Dyno tests are interesting as well.
#7 ROYAL PURPLE 21 SYNTHETIC (no SAE
rating - analysis suggests around 0W-30)
RPM 3000 3500 4000 4500 5000
Ft-lb 265 307 304 301 279
HP 151 205 231 257 266
Maximum HP: 266.6 @ 5000rpm
Maximum Torque: 314.9 @ 3750rpm
Oil temp: 200F
Oil pressure: 52psi
Water temp: 190F
#11 MOBIL 1 0W-40 SYNTHETIC
Ft-lb 268 311 304 300 283
HP 152 207 231 257 269
Maximum HP: 270.5 @ 4950rpm
Maximum Torque: 318.3 @ 3700rpm
Oil temp: 206F
Oil pressure: 52psi
Water temp: 190F
#10 AMSOIL 2000 20W-50 SYNTHETIC
Ft-lb 262 297 305 296 274
HP 149 197 232 253 260
Maximum HP: 261.7 @ 4950rpm
Maximum Torque: 312.3 @ 3700rpm
Oil temp: 200F
Oil pressure: 52psi
Water temp: 190F
Good Morning Tilt!
Royal Purple is an excellent choice! It came in second behind the top Japanese oil company's synthetic brand which made almost three additional Hp on the dyno.
The issue people were having with Royal Purple back when it first came out was , they were buying the racing oil thinking it would be cool or would give better protection. Well, racing oil does not offer better protection for street driven cars. It contains absolutely no detergents and other agents that are used for DD cars. Racing oil is meant to be changed after every race.
Also, Im sure T would agree to this...stay away from Fram, their filters do not hold or retain contaminates well and they break up very quickly. K&N oil filters are one of best available, the other being the S2000 OEM filter which Janne over at OCO swears by.
peterbilt
when im broke and the store is not having a deal i get syntec blend and the cheapest filter
^^Look up
Whatever man.
Unbiased tes results don't lie. It was'nt like it was Royal Purple that ran the test. Mobil 1 is garbage compared to RP.
^^Look up
Troof eh!
Whatever man.
Im not arguing with you.
If you looked at the test I posted it shows that RP is good stuff, but that test also shows that Mobile 1 is good stuff too.
1 - 20 of 49 Posts
