I have a 91 CRX HF with a bad motor. Boost is in the works. I am planning on either:
A. Buying a good a6 shortblock and adding head etc from a a6 with 200k miles and bad rings.
B. Buy a SOHC ZC from hmotors
My tranny options are
A. 200k mile si tranny from an ef
B. Use my HF tranny.
What should I do?
Thanks,
O
the Z6 is going to rewuire a lot fo rewiring. someone said there is a adapter that allows you to use the obd-0 with obd-1 ecu and harness or something, anyways, you will need the z6 harness, ecu and engine. if you run that. it woudl be a good option for boost. the A6 is also a good candidate for boosting.
