1 - 16 of 16 Posts
looks like a z6 head with a ghetto speedfactory breather
Reactions: robgoof
MuthaFuckaUppa
2009 Civic Si Sedan
Good find, maybe. You have VTEC. What does the block say? You may have a post turbo motor.
135730
MuthaFuckaUppa
2009 Civic Si Sedan
The block will have the motor code on that flat spot.
With the dip stick on the front of the motor and not built into the timing cover, it will say D15B7, or D16Z6 etc.
If that is a fitting on the oil pan it is not stock. Someone added it. The exhaust manifold is a DC or a knockoff.
Is that an external coil distributor cap I also spy?
My guess is someone had a turbo motor, and blew it up, swapped the turbo bits off, and junked it if you found that in a junk yard.
look at you guys with the eagle eyes!
Reactions: EFB055
93 Civic HB SI
Any information you can provide us would be extremely helpful. We really don't know what we have here. Thanks
Like Criptofer said and spelled out for you in the picture he attached, clean the block label and determine the block code. We will be able to tell you if the head matches the block code or if the head is different.
He also caught all of the pieces that indicate it was probably turbocharged at one point. Maybe you got lucky and have some nice forged goodies inside?
how else they gonna stunt on people? lol
Reactions: robgoof and Evanguy
Never finishes (TWSS)
91 Civic SI hb/ 01 GSR
That motor looks like something Rob should have. And as ghetto as the crank case/ valve cover vent looks i bet it would work well
Sloppy Jalopy
I bet the vc vent was added after it started to have massive blow by..
Too classy for me..
1 - 16 of 16 Posts
