1 - 9 of 9 Posts
T
I just purchased a DOHC ZC for my 1991 CRX. I noticed when I went to pick it up that there is some sort of black plastic electrical part on the intake. This part is broken but it looks like it is riveted to the intake. What is this and can it be replaced or do i have to purchase another intake manifold.
Thanks.
T
where would I get it and how do I replace it since it looks as if it is riveted on?
H
I must agree wit SiVIC sounds like the TPS, which can be replaced wit a little calibration of course....but pictures would definately help.
It is the tps and you need to get a dremal tool and grind a knotch into the rivet so you can use a screw driver to unscrew it.... it looks like a rivet but it is a bolt with no head on it.....
T
Can I just use the Throttle Body from my d16a6 motor? they look the same. If so, will I still have to get it calibrated?
1 - 9 of 9 Posts
