1 - 20 of 21 Posts
crx and ford ranger
i go these injectors for free from a good friend of the family at his junkyard and they came off some unknown honda and plug right up to my OBD-0 crx harness i know they cant be stock or atleast i hope not there really fucking fat and stumpy with a red top
only numbers i can find
js21-1 3621
i mean idk if there part numbers or not already did a serach cant find jack
crx and ford ranger
Discussion Starter · #2 ·
can anyone put me in the right direction here need to know these befor my basemap and tune gets done please thanks
crx and ford ranger
Discussion Starter · #7 ·
thanks alot Ryan yep they came outta modded 94 civic ex coupe with some head work and built boosted bottom end
but thank you for finding the cc on them your the man for sure
crx and ford ranger
Discussion Starter · #8 ·
this brings my next question how far can i go with these injectors good enoght for 7-8 psi on a good tune ?
crx and ford ranger
Discussion Starter · #10 ·
well it doesnt come with one stock the car they came off of was a 94 civic coupe modded dont know if there was a resister box or not on it..
95 civic ex coupe
they look like redtop dsm.. im not sure tho
crx and ford ranger
Discussion Starter · #14 ·
they look like redtop dsm.. im not sure tho[/QUOTE
to my knowledge which could be wrong there is not such thing as Red top injectors from DSM.. and they are ford mazda injectors cause i took them to a mazda buddy of mine and showed them to him..]
crx and ford ranger
Discussion Starter · #15 ·
o0o and resister boxes also came on the older Integra too
It says on the picture that they are 12 ohm injectors. Eg/ek use high impedance(12ohm) and ef use low impedance(2ohm) unless it hass been modified.. I am pretty sure that if you are running a p28 you need high impedance injectors. Don't quote me on that.. Some with if you are running a pm6 or a p30 you need low impedance one!
95 civic ex coupe
p30 is the same as p28.. except b16 maps and knock board
injector size / 5 * number of cylinders * .8 = estimated HP injector will support
280/5 = 56 * 4 = 224 * .8 = 179
so somewhere close to 180 at 80% duty cycle
p30 obd0 uses low impedance and p30 obd1 uses high impedance. P28 is obd1 so it also uses high impedance!
1 - 20 of 21 Posts
