1 - 18 of 18 Posts
Civic EK
Hi guys
i have a d16zc forged turbo etc... looking to get 300-350whp
but dont no what fuel injector to put in , high or low independance ? how do i no wich one to take :p
lokking to buy pression 780cc for the price its pretty good i think
thanks for all you help fellows
:3dbiggrin:
Formally D_Tuned
97 civic HX
You can run either High or Low Impedance injectors on your honda, the only difference will be the Low Impedance Injectors will require Current Limiting Resistors in order to prevent premature Injector driver failure in your ECU
Civic EK
i said wich one is safer because ,you said the low independence can cause ECU failure, if under stud well .?
Wich one between the both dosnt need a resistor ? :p
You can run either High or Low Impedance injectors on your honda, the only difference will be-
If LOW Impedance injectors NEED a resistor, then HIGH Impedance injectors...?
As for what size injectors you need:
http://www.gtsparkplugs.com/InjectorSizeCalc.html
My civic
injector dynamics is the way to go...same price for 725cc or 1000cc...you will not regret it...best injectors out there!!!
2000 civic 2 door ex
1000s
1 - 18 of 18 Posts
