1 - 16 of 16 Posts
90 CRX Si
Well, i'm trying to find an adjustable FPR for my NA build i'm doing and i need a bit of help.
First of all, i don't know how well the B&M units work, the Command Flo modifier ones that fit on your stock FPR, but they are cheap.
Secondly, here's a Holley unit, but i don't know much about it, but i can get it through my store for cheaper than this, but here's a link. Also, will it fit stock fuel rail?
Holley FPR
Or, i could get the AEM adjustable FPR. My only concern with it is i wonder if it will bolt to a stock fuel rail.
AEM FPR
Aeromotive, Holley, AEM
How much you wanna spend?
But for NA build, why do you need a FPR? Stock will be fine, the rest is tuning the ECU. Spend the $150-200 on tuning time.
Oh yeah, I have the Aeromotive, twas a time I could afford it with the ZEX kit.
90 CRX Si
Well it might get a little spray later on, when i get some more money. So you think it'll be fine until i get the spray on a stocker?
**EDIT** Forgot to ask, but all those will fit to stock fuel rail, right?
'02 Civic LX Coupe
Yeah, you will be fine. Stock honda fuel systems work well up to 200WHP i beleive if oyu are tuned. COrrect me if i'm wrong d-series gods.
only reason for a FPR on a typical NA build, so you can tune before/after your tuner does his job.
formerly allnaturalrex
1989 honda crx si
b&m fpr ftw!!!!!!!!!! but i agree with the rest no need for a fpr the stock one is fine but still is needed in some cases.
1989 honda crx si
So you've had good luck with the B&M?
yes sir but shit since your thinking about nitrous i think the holley or aeromotive should be good sorry didnt read the rest in your post.
B&M should be fine, even Endyn uses those, I got one for my new intake setup too..
B&M is nice, until it sticks open and you have 5psi fuel pressure.
The weekend that it happened I was supposed to race, with the ZEX kit.
85 shot and no fuel? Guess how big the bang would have been?
94 civic... duh
Whats the white stuff??? you get little excited when you opened the package??? LOL:alky:
thats the way it was painted from Aeromotive. Since it was an "import" application they riced it up a little.
1 - 16 of 16 Posts
