Hi everyone,
I need some help with my daily driver. It is a 1998 civic ex with d15b7 swap and a p75(yes the integra one) obd2a ecu, Previous owner did this, The engine is completely obd2 and just recently passed inspection. However the car runs rich as to be expected and is sluggish. I would like to put the proper p06 ecu in however I would have to convert to obd1 and then I would fail inspection next year. Is there an easy way I could swap in the p06 and then back to p75 when inspection time comes? if not is there any obd2a ecu that would work better than what I got? I know the ecu out of the y7 wont work because of the smaller 180cc injectors and something with the 3 wire icav. Any help would be greatly appreciated.
-Steve
you could buy an obd1 to obd2 jumper harness and run the po6
If is to rich you can.. ReMap the Ecu.. o Use Hondadata S300 I think making your own map you be able to manage the Emitions and get some extra hp's
