1 - 4 of 4 Posts
T
I put a d15b JDM motor into my '93 CX hatch, and I have the p05 ecu and I'm having problems with the vtec. Do I need a p08 or p28? help please.
Worst Mechanic Ever!
EG
P08 if I'm not mistaken. Just search forums for "D15B ECU", there are lots of threads on it.
which ecu is right
whats going on? you can use either the p28 or the p08
i have the same setup as you but i am using the p28
i suggest you run the po8 though more aggressive fuel curve and ignition timing
didn't i reply to a thread like this already? Yes, easy way is to get a p28 or a p08 (p08 is meant for the d15b)..
Cheap way is to take your current ECU and convert it to a vtec ecu... see my sig.
1 - 4 of 4 Posts
