1 - 7 of 7 Posts
block
d16y7 sleeved
cp pistons
eagle h beam rods
eagle crank
head
d16y8 vtec ported & polished
3 angle vavle job
new stainless valves
drivetrain
stock lx tranny (for now)
act clutch &flywheel
turbo setup
t3/t04e
log manifold
2.5 icp
tial 38mm wastgate
greddy bov
electronics
hondata s300
innovate wideband
fuel
walboro 255 hp pump
dsm 450's with resistor box
aeromotive fpr and guage
ditch the y7 block and get a sleved z6. to many issues with the oil pumps. fjt custom i beams and vitara pistons would be a much cheaper but still very solid option. and dont waste the money on valves. if anything get TI springs and retainers. unless there is something specific u are after with the hondata i would go crome chipped ecu. and with everything u are listing(without knowing your power goals) i can guarentee those dsm 450's wont hold up to the power this set up could produce.
oh....and there is no need for a new crank. if anything just micropolish yours and plastiguage bearings accordingly. we can help u out alot more if u give us details on what u are after. street/track? hp? brand of turbo? trim? sooo much more.....
Friend of the D
mrfunktastic is right on the money! :TU:
I would also note that stock sleeves are good to at least 400HP, which is pretty much the limit of what you can get on pump gas on a d-series anyways. (probably closer to 350WHP even!)
Also, if you are going for the numbers, ditch that log manifold and use at least a mini-ram. Add some 750cc injectors and you'll be on your way.
if you are gonna run a 2nd Gen Mitsu or Nissan turbo. T2 flange. SLS has a ram horn for T2 with 38mm external gate. I believe its 550 right now already made been sitting on the shelf. They want rid of it.
1 - 7 of 7 Posts
