Hey guys, my d16y7 needs a new crank and probably a rod or two. the GF ran it too low on oil and now its knocking ( not too happy with her).
Now my question is: Will any d16 crank/rods work? d16a6/d16z1 etc etc?
Or will ANY d series crank/rods work? d15b2/d17b7 etc etc.
Thanks for any help, you guys rock.
Never finishes (TWSS)
91 Civic SI hb
you will need a any sohc d16 crank that is not a 88 d16a6 crank. also any sohc d16 rod will work
91 Civic SI hb
you need a crank angel sensor in the timing gear and im not sure is the timing gear you need will fit other cranks the a y crank.
also if im wrong about this and you can use other cranks. yes an 89 a6 crank will work. the crank pully end on the 88 is smaller then all the other ones
