1 - 11 of 11 Posts
Y
Alrighty guys. I am buildin a mini me with a d15b7 block, d16a1 pistons, and a z6 head.
my question is what engine bearings should i use?
just normal d16 or d15 bearings,can someone please help
thanks guys
me
Y
sorry,am using the crank and rods from the d16a1 also,so get them for the a1, or are all them the same
D
Can you put d16 rods in a b7? Didn't think so, but if I can I'm rebuilding my b7 instead of switching.
I was thinking the same thing...I didn't think you could put those in the B7 safely.
But if you did go w/ he a1 setup I would think you use those bearings, but not 100% on that...
D
You use the bearings made for the rods, I know that, and the rods should always match the crank. The b7 rod ends are like 45mm and the d16s are 48mm. Don't think a 1.5mm rod bearing is out there. If it is and works let me know.
Y
well if i cant use the rods and stuff can i use the pistons on the b7 rods and stuff
Y
i thought the a1 piston would raise the comp
Y
would putting zc pistons in the b7 block raise the comp
1 - 11 of 11 Posts
