1 - 9 of 9 Posts
at which point in the fuel table? idle? cruise? wot?
Retired From Hondas
If its still in closed loop it will be all over the place.
Im trying to understand the point of the question...
warmed up, 14.7-16:1, depending on how good your injectors are you can run a little leaner
Black/Green Civic HB
Can't be too much richer than 14.7:1, I only see a couple mpg (~2) drop when a o2 code is being thrown on my 00' 4dr stock set up
I would guess it would be in the 13's afr
ej8
with o2 disable/ unplug?
Yea I can't remember what stock was. I believe it was in the 13s .Trying to dial in idle and keep the ecu happy.
factory no idea, but as said above, ~14.7 is fine. some tuners run slightly rich in that area to speed warmup
Ek sedan
Mine is usually 15+ when warm, 11-12 cold with o2 disabled.
1 - 9 of 9 Posts
